I have a 99 2 door XJ, 4.0L 6 cylinder 4x4. I recently replaced the distributor after getting a check engine light for the camshaft positioning sensor. I started it up and it ran fine after a test drive. The next time I started it up it ran very tough, sputtered and threw a code. I removed the distributor, repositioned it and after replacing the problem seemed to be fixed.
However, shortly after replacing the distributor, I started getting a hesitation from my engine at freeway speeds. It seldom happens in a lower gear but it feels like the jeep is hiccuping. Its a very unsettling feeling and I want to address it and fix it as soon as possible. There are no codes that pop up when this happens and it usually happens between 50-70mph. Any ideas of what to check or where to start?
I also recently got a code p1694 and p1698 not sure if these could be related but thought I would mention it. These codes have come and gone and im not sure if it is the TCM or a wiring issue.
Any help would be greatly appreciated.
