Engir Active member Wednesday at 3:20 PM #1 The images below are of a relay mounted on the drivers side fender next to the air box I have no idea what it is for? In that same area by the air box there is this reply I have to same question? Thank you
superj Well-known member Wednesday at 9:58 PM #2 That second one goes on the plastic bit on the wall above it. Its supposed to slide on to that bit. Do you have fog lights? The first one oddly looks like a fog light set up that someone added
Engir Active member Yesterday at 12:35 AM #3 superj said: That second one goes on the plastic bit on the wall above it. Its supposed to slide on to that bit. Do you have fog lights? The first one oddly looks like a fog light set up that someone added Click to expand... No I sdo not have fog lights. The second one that image is taken by the headlight the wires go into the headlight harness if I am remembering right would you have any idea what is for?
