Jack tools missing
Thanks for the pic. It was killing me wondering. Ooo! So close! Looks like little grinding and paint???
Regards,
JPNinPA
Sent using TapTalk
tilt the handle so the hook part fits into the jack.
Yeah, I tried that. You can see in the picture the paint worn off the tip where I tried every which way to get it in.
JPNinPA, ​A little grinding would make it work.
Does all the pieces fit nicely together making a solid rod?
Could the rod be used at different lengths?
I recently used mine to hold the axel during a lift and rear track-bar install. It would have been nice to have a short rod to use occasionally . It’s sometimes awkward having a big one. It just gets away on you.
I see the Dorman ones on Amazon but can't find one that says it's compatible with Jeep. I guess all you need is something to slot into the jack so you can crank it.
Yeah, pretty much. I could have made the one I had work with just a little grinding.
