bradleyheathhays
Member
Been spending the past  couple days cutting out and pressing in my first  bushings and so far,  well mostly good.  Got the leaf springs off the 96  XJ and finally got  all the bushings out.  Pressed the smaller rear  bushings in first and  both went in using a 2 ft breaker bar and a ball  joint kit w/ the big C  clamp and cups etc.  The bushing OD looked  slightly larger than the  hole it was going into and took all that  breaker bar to get it in  place.
Problem comes when I start on the larger front bushings. I get the first one started w/ my masons hammer and lo and behold the whole thing goes in fairly easily with less than 10 moderate blows. Not sure it's weight but it's like a mini sledge. After it's in all the way it feels solid with no movement but it's fit isn't nearly as tight as the rears. Same bushing on the other leaf spring goes in the same way.
Besides forge heating and reshaping the end of the leaf springs is there anything I can do to make these bushings fit any tighter?
