Pay someone else to do it.
The only issue you will have is the spring mount bolts will probably be seized in the bushing sleeve.  my little trick to getting them out is as follows:
take the nut off
put another nut on, then I install my bolt smasher outer tool
sinch the two together and spend the next 5 minutes smashing out the bolt with my mini sledge.
Now my bolt smasher out tool is nothing more than a nut with a 4"x4" piece of  1/4 steel welded to it.  when I thread it on, I thread till it bottoms out, then 1/2 turn back, then use the other nut to secure it (double nutting) don't want to bottom it out, will mushroom the threads.
