Just bought a 1981 cj7 that has a 4" lift on it, my questions are:
1)Front height from ground 27", rear height from ground 25.5" the shackles on both the front and rear half lower holes, can I simply move the rear spring to the lower set of holes to help level the jeep up?
2) front extremely stiff, I read some where that I could remove the stabilizer with no ill effects to help the stiffness of the front end, is this correct?
3) when accelerating hard the jeep pulls to the left, is this do to not having a locker in the rear? can I put a spool diff in the rear?
it is a 20 series with solid axles
I know this is alot of questions, but I am 33 and re-entring my childhood!!!!!!!!!
THANKS
THANKS
