New Revolution Jeep Gearing packages available now!
Allen's Offroad
Lot's of new package deals for you guys. Same warranty, same quality, same everything. Free Shipping as always for these. California residents add 7.5% sales tax.
For a limited time only, mention JEEPZ.COM and get 10% off pricing below.
Rev-JK-Non-456 JK Non Rubicon (D44/D30) 4.56 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Non-488 JK Non Rubicon (D44/D30) 4.88 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Non-513 JK Non Rubicon (D44/D30) 5.13 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Rub-411 JK Rubicon (D44/D44) 4.11 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-456 JK Rubicon (D44/D44) 4.56 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-488 JK Rubicon (D44/D44) 4.88 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-513 JK Rubicon (D44/D44) 5.13 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-538 JK Rubicon (D44/D44) 5.38 gear package front & rear with master overhaul kits $660.15
Rev-TJ-D35-373 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 3.73 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-410 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-456 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-488 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-513 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D44-373 Jeep TJ (D44/D30) 3.73 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-410 Jeep TJ (D44/D30) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-456 Jeep TJ (D44/D30) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-488 Jeep TJ (D44/D30) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-513 Jeep TJ (D44/D30) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-Rub-456 Jeep TJ Rubicon 4.56 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-488 Jeep TJ Rubicon 4.88 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-513 Jeep TJ Rubicon 5.13 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-538 Jeep TJ Rubicon 5.38 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-YJ/XJ-D35-410 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-456 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-488 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-513 Jeep YJ/XJ 84-96 (D35/D30 reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D44-410 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-456 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-488 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-513 Jeep YJ/XJ 87-96 (D44/D30 reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-XJ-8.25-410 Jeep XJ 91-99 (8.25/D30reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-456 Jeep XJ 91-99 (8.25/D30reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-488 Jeep XJ 91-99 (8.25/D30reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-513 Jeep XJ 91-99 (8.25/D30reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-373 Jeep XJ 96-01 (8.25/D30 short) 3.73 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-410 Jeep XJ 96-01 (8.25/D30 short) 4.11 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-456 Jeep XJ 96-01 (8.25/D30 short) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-488 Jeep XJ 96-01 (8.25/D30 short) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-513 Jeep XJ 96-01 (8.25/D30 short) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-D35/D30S-373 Jeep XJ 96-01 (D35/D30 short) 3.73 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-410 Jeep XJ 96-01 (D35/D30 short) 4.10 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-456 Jeep XJ 96-01 (D35/D30 short) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-488 Jeep XJ 96-01 (D35/D30 short) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-513 Jeep XJ 96-01 (D35/D30 short) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-ZJ/WJ-410 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.10 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-456 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.56 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-488 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.88 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-513 Jeep Grand Cherokee 96-04 (D44HD/D30short) 5.13 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Let me know if you want/need a carrier or locker. Now online at Allen's Offroad. Use coupon code "REVPKG10" at checkout for the additional savings.
Have a blessed and prosperous day!
Allen
