fast_Z28_guy
1 245/75r/16 goodyear mt/r tire
hey guys, i was gonna post under my GF's screen name...she's new too...since she's the one who wants to buy a jeep. but i figured i would just create my own name. this way she can add her own information and views.
she wants a jeep...i'm the "car guy" so she wants me to help her research what to buy and what NOT to buy.
i'm new to jeeps other than driving a friends mid 90s jeep. i've got plenty of car experience. i've owned 3 camaros, an 87, 96 and now a 99. i've rebuilt suspension, installed a clutch and done some pretty in depth upgrades by myself. so wrenching is not new to me. my current ride, the 99z28 is pushing 400hp to the wheels
i'm also not new to message boards...been on a camaro board with nearly 50,000 members for about 8 yrs.
i went ahead and read the first 6 pages of the CJ YJ forum and have some questions. answer the ones you can. be as simple or specific as you want. i'll figure it out.
1 - what is the difference between the CJ, YJ and TJ?? is it just like the "generation" of the jeep? like 82-92 camaros are 3rd gens, and 93+ are 4th gens? or is it something more in depth?
for the techincal stuff...this is going to be a daily driver. no real offroad stuff (no moutains in florida...just mud), possibly towing a small boat (if i ever buy one)
2 - was reading a post about reinforcing the frame. i know sub-frame connectors make a huge differnce on the camaros, but they have unibody construction. the post mentioned reinforcing the steering box mount. i understand how having wider tires can increase the stress on the mount. is this a common problem? is there a simple fix? i know this was common to the early 80s camaros/firebirds and they sold a "wonderbar" that mounted behind the steering box to strenghten it. anything similar with the jeep?
3 - since i'm looking at used mostly. what is a good milage to look for? i don't WANT to rebuild anything...even though i know i could. so for daily driving and minimal offroad...what is a good milage to look for...or avoid?
4 - how strong is the auto trans? typical clutch life for the manuals?
5 - how difficult is the rear main seal to change. i know this is a common problem on alot of vehicles. saw it mentioned several times. average life?
6 - trans fluid. saw something about Chrysler using the wrong kind, GL5 and it causing blown transmissions. is this something common that dealerships screwed up? or was it written wrong in a manual? is it smart to change the fluid straight away...just to make sure? granted i'd probably do ALL the fluids just so i knew they were good, to start fresh (good idea with any car i think).
7 - what year did they change to obd2? probably the same as most cars...1996. is there any advantage to obd1 over 2 when it comes to ease of maintainence? i know with obd2 on the camaros you run into some sensors that are more of a hassle when you start modding. is there a way to check "Service Engine" lights without a scanner on any of the jeeps?
8 - when it comes to swapping tires...how easy is it to recalibrate for bigger tires? i know in my 99z28 it has to be done in the computer. my old 87 you could do it with speedo gears. i don't want BIG tires, but those dinky stockers are kindda BLAH.
LAST AND MOST IMPORTANT
DEATH WOBBLE:
sounds like it is caused by a combination of things. worn out parts, bushings, bearings etc, and a specific speed and road condition. i would assume proper maintenance...or preventative maintenance...would reduce the likelyhood of this happening. is it more prevailent with bigger tires?
DEATH WOBBLE:
