Dragon5126
This might be lengthy so bear with me. I'm at a loss so need some advice.
I've got a 77 CJ7 with a 304. My steering box went bad so bought a replacement. I also wanted to pull my engine to paint it AMC blue. I didn't have the means to pull the engine so I found a guy to do it. Now, it was running fine at this point. No issues...only the steering box problem. Well, after 6 months of my Jeep hanging out at his garage without an engine in it, I literally had to pressure him to put it back together...this is where everything started going bad.
I got the Jeep back to the house and it wasn't running good at all. This was about the time when I found myself going through a divorce so I didn't crank it for about a year. When I was able to get it from the house, it wouldn't crank at all. I don't have a good place to work on it at my new residence (divorce sucks in more ways than one) so I found a mechanic to work on it. What I've found is a lot of people don't know how to work on conventional engines anymore. Anyway, this is what has been replaced on this Jeep:
- Plugs
 - Wires
 - Distributor along with cap and rotor
 - Starter
 - Ignition module
 - Carb cleaned
 - Couple years ago, electric fuel pump was put on
Now, I'm guessing the plug wires are connected correctly and the timing is properly set. The problem now is what sounds like a misfiring but the major problem is the carb loading up with fuel. If it sits and idles, it will load up and die. At speed, there's a lack of power. I've checked the float..its not stuck. I don't know what to do with it. If the timing was off, would it cause excess fuel in the carb? btw...I asked the mechanic if the fuel pressure was about 4-5 lbs? He said the pressure is fine but I quote him..."something else is wrong with it."
Unbelievable. Any ideas? Thanks in advance!
This is where the old engineering adage of the KISS PRINCIPLE comes in. (keep it simple stupid) return as much of it to original as you can and start from scratch. this means pull the cap and cables make sure the cap and rotor are good, reinstall, check the plugs and cables and make sure they are installed in the correct orientation, reinstall a Mechanical fuel pump and go from there
your fuel issue needs to be dealt with first or you cant be sure about the rough running. a mechanical pump will eliminate the possibility of fuel pressure regulator issues and the electric pump causing problems. (don't forget to change your fuel filter) if/when this corrects the fuel delivery problems look to ignition issues for rough running. if it doesn't correct fuel delivery issues look to rebuilding the carb as improper cleaning (removal and reinstall as well as reassembly) can create issues as well. but ALWAYS chase just ONE ghost at a time until it is logically eliminated or you will just be chasing your tail. Since fuel delivery is the most obvious issue right off this is the place to start, and an engine on the edge of flooding will run bad, so eliminate fuel issues first.
