Andrew Mac
Member
2004 TJ, 4.0, Auto, A/C. 20500.0 miles.
Ongoing issue ( 6 year+) when engine is hot, when restarting will intermittently throw a 303 code ( number 3 cylinder misfire ).
Over the years I have replaced Spark Plugs, OPDA, Coil Pack, Fuel Injectors, Fuel Pressure Regulator, Duty Cycle Purge Solenoid. Problem still persists.
Recently a new issue has developed. While traveling down the highway. 65 MPH, A/C on, loss of power and Engine Temp red lines.
Pull over, shut down, sit for 20 minutes or so, restart, all good.
A/C seams to aggravate the issue. Drove 200 miles freeway, no A/C, issue free same day.
After reading up on the PCM I'm thinking I could have a bad Coolant Temp Probe? A bad MAP probe, bad Intake Air Temp Probe?
All three of these items send info to the fuel metering process?
Chasing intermittent issues is a pain in the butt!
Has anyone experienced issues like this? Any suggestions are greatly appreciated !
Thank you,
Andrew~
Thank you,
Andrew~
