pdparker said:
Go traditional. It will save you a few bucks for sure! It'll probably be stronger to.
not to bew argumentative but I have a chance to get this thing for $300.00 brand new. I called ROad Armor yesterday and found out they sell for $1160.00. They weight 125 lbs and stand off the front a foot.
"This Bumper is made of the 3/16" highest grade ASTM A36 descaled and oiled sheet steel materials, with a minimum yield of 36,000 PSI. This high grade steel is clean of any mill scale and presents and superior finish for Powder Coating , Armor Coating etc.
Pre-RunnerGuard is made with 2 " OD X .120 Wall mandural bend tub for the side guard
Engineered to fit the 97+ Jeep TJ as if it was stock application. Fits up around the grill and along the finder line like factory. This bumper has been laser cut hand broke and welded.
Ready for Warn or Mile Marker Winches up to a 9500 lb. Light Cans are build around the PIAA 510's and 1100's
This Bumper will set your vehicle apart form the others. A cut above the Rest.
Weight 125 lbs.
100% 3/16" Steel
Shackles for Pulling
Adds a quality look to your Rig
All hardware provided
$1158.00"
I don't know,... I personally like the look, and it will be taking A Lot of abuse rock crawling (you should see the stock bumper on there now,... it's funny as helll!) My only worry is functionality, is it going to kill my approach angles. Thanks for the feedback everyone, this is what I wanted, opinions and testimony.
