Running stock
03-TJ
I was told I can run 31's on my stock 03 "x".
Is that true or was the guy full of it :-?
Any help would be great (not to sure about backspacing etc...) 8-)
I just got my new Jeep (had a 95 yj) about 2 weeks ago so I'd rather not lift it right away.
I want to run the biggest tires possible without rubbing or lifting it.
Thanks all!!
:-D [addsig]
1070875
Put in some spacers and I think you can only a little tight. I am not a TJ guy so some one with more info will be along soon! tug[addsig]
1070877
31" tires will be fine on stock. Do the 2" budget boost (coil spacers) when you can afford to, nice addition to 31" rubber 8-) [addsig]
1070878
What are coil spacers?
Is that like the cheap 2 inch to 2.5 inch lift I see in the quadratec catalog?? :-? [addsig]
