Pardon my intrusion , didn't want to just start posting especially when flatle46 has given some excellent tips to get the job done , definately look for those clips he spoke of , Eastwood should have them . They hold the panels together like a third hand and at the right space perfect for a butt weld , the preferred body panel weld . That's the fastest. Just wanted to say that's a sweet jeep and it deserves to be repaired the best you can , I agree . Everyone has their favorite method to get rusty nuts and bolts out , but its no ones favorite job . It's time consuming as it is a schedule breaker. It sets you back . Takes a minute or less to unscrew a nut or bolt but longer to much longer to get a resty or frozen one off. Well , get on a good pair of eye protection and a dust mask too and on a grinder , you can mount a wire wheel and start cleaning the rust. You can use a wire wheel mounted on a drill too but the grinder just works harder and faster. Now soak it with your favorite penetrating oil and give it PLENTY of time to soak in. Multiple applications will be necessary by the look of things in your photos ! Those bolts most likely penetrate the floor on a captured nut ( welded in place ) so you may try to squirt the thread from below too . If you got impact sockets , put one on it and rap,it with a ball peen hammer to shock it. Now try to turn it with a ratchet but use restraint as you can snap it if you don't strip it. Try to work it back and forth , tighten and loosen , but not too much force. Develop a feel for the bolt. You can tell if it is twisting and will sheer off. It will suddenly get too easy and fool you by thinking its loose. If you do snap it or there is no hope because its too corroded and frozen , the head will snap and a stud will be left. You can continue to try to lube it with penetrating oil and if there is enough stud left to double nut it ( one nut tightened against the other ) and work it off with the lower nut.
If too short , cut it flush and center punch it and prepare to drill a hole for an e-z out . There are studs extractors that grab a stud like a drill bit and spin them out , but you got to use judgement to decide what will work versus what you got on hand. Since you got plenty of time before the day you jump all over this job , spray the bolts often and maybe enough rust will dissolve and give up the fight and you will win ! I got a fitting off an intake manifold on a 4.3 v6 Chevy s-10 for the heater core hose and we sprayed it almost every day for days or weeks until we got to the job as other things were to be done too , like a timing chain and water pump . They are notorious for snapping and must be extracted but we gave it time with plenty of lube and the fitting came out like butter ! Those bolts are rusty but not too scary looking looking . Clean them well and soak them good , I think with a little patience , you'll get them out. If you manage to break one or two , we'll probably all give our favorite method of broken and frozen bolt/nut removal recipes like attaching jumper cables to both sides of the bolt for a second to get it hot and then quickly attemp to unthread it . Don't do this though , that's an act of desperation . A torch works well but were trying to get the bolts out without burning the paint or light the jeep up ! Don't do that either ! Just start soaking them and you got a very good chance of clean removal but patience will prevail . If you rush it , just more work for you . Try your hardest to SAFELY get them out CAREFULLY and "feel " if the bolt is turning or not . It's how we all learn. Like I said , we could start a whole thread on our favorite methods ( I could , lol ) but give it a shot and let us know how it works out . Best of luck to ya ! Greg
oh yeah , as previously mentioned , if the rust cleans up well , POR 15 is a great idea if it works out that way . But one section of floor pan has got me guessing .
Might have to cut . The die grinder/ wire wheel will tell , wear good gloves too !
if e-z outs aren't your thing , you can progressively dril from smallest to biggest drill bit to just under the stud size and retap the thread afterwards . Like I said there's many ways to deal with rusty nuts and bolts !
