greg92jeepxj
Official Supporter
The die grinder and wire wheel as previously posted will be very useful in the task of removing rust. They take no prisoners , they just get the dirty job done. In your search for sand and bead blasters , you may have run across soda blasters too , but keep in mind the soda blaster will only remove paint down to the metal. The nice thing is , soda does not remove any of the factory applied chemical agents that are rust preventatives. You can buy time without the fear of oxidation setting in quickly , but only for so long as well. Soda blasters do not remove rust , so yes , you will need a bead blaster or possibly sand if the corrosion is that heavy and from your pic's , some of it is. Not having seen the chassis , I can imagine that you probably have heavy surface rust . One thing that every jeep needs ( every car too ) is chlor-rid , a chemical remover that washes away the corrosive agents found in rock salt and calcium chloride ( I think that's the name) for snow and ice melt. These chemicals stay on your jeep body and chassis unless washed thoroughly . Supposedly autozone carries it ( on-line?) bit whatever we find for this purpose , we all should make use of it. Back to the bead and sand blasters , when using bead on less corroded surface , a good wash ( even preparation solvent) to remove all traces of this calcium chloride is very important as you don't want to prime and paint over poorly prepared surface and watch your jeep rot from the inside out after all that work. The sand blasting will immediately expose a shiny but very susceptible surface to oxidation , a prelude to rust . Since sand blasting literally takes off minute layers ( almost microscopic) of metal that is fatigued , you MUST immediately epoxy prime or use some of the products EASTWOOD vends for this type of restoration your doing. Although your just doing a repair , it is in the form of a restoration. Who knows , partial disassembly may be entailed. Your already removing seats , you may find yourself removing a crossmember or brake or gas return line or vapor line or something just to wield that Sand/bead blaster. You don't want to damage soft metal , sand and bead can do that. Please , as you are currently doing , plan ahead and have your supplies , job goes quicker and less chance the atmosphere will take its toll. You got a really nice jeep , we would like to see you return it to show room new as I believe you are setting out to do. Well , maybe not pebbles beach or Barrett -Jackson , but there's something about a jeep that its chassis is CLEAN just makes you shake your head "YES" ! I know a jeep is a work horse and it will get dirty and age the underbody , can't help that, but we can try. For your purpose , the sand/bead blaster will achieve great results , with the right media , of course. There most likely are other products and methods I may be unaware or, I'm sure another member may post of these as well. My brother sold his bead/sand blaster (lack of use) , wish we still had it. Very useful. Lot of clean up though.
Youll be shop-vacing sand from EVERYWHERE! That sand just finds its way into places where you must pressure wash to get it out. I'd say the blaster will make quick/through work of your intentions to rid your jeep of rust. Grinder, wire wheels and cups, blaster , the more tools in your arsenal , the more options you got to remove light, medium to heavy rust and corrosion .
There is an attachment that goes on air tools that whips rust off that is like flogging , can't remember the name of the tool . Never used it but heard it is great on heavy corrosion too.
Is used quite extensively on tractor trailers as they run I to a lot of salt treated snow in winter months and need to be treated with this attachment. If I can remember the name , you could research that as another weapon in the war on corrosion. Well , just some more thoughts . Hope this helps too . Greg
