RE: Re: RE: Chevy versus Moose
Hi,
So, I've been working under my wrangler lately, and have decided that I really don't like the big plate they used to mount the transmission and transfer case to the frame. It appears to be a mount and a skid plate all in one. I find it annoying because, being the large flat piece of metal it is, it blocks easy access to most of the drivetrain (the transmission, transfer-case, part of the front drive shaft, etc...).
It appears the entire drivetrain is supported by this pan mount, and if I want to, for example, remove the front driveshaft to replace U-joints, I have to remove the pan, leaving the drivetrain floating in the air on a jack (which scares me because there is not a good place to put a jack under this transmission while the pan mount is installed. :shock: )
I was wondering if this plate type mount was an option on these TJ Wranglers or if that is how they all are. My thinking being that if it was an option, I might be able to locate a thinner crossmember to use to mount the transmission/ transfer-case with instead of this big pan. Of course, I suppose I could easily build a new cross member for the transmission/ transfer case and then modify the pan to mount OVER it, allowing easy removal of the pan when I need to work under the Jeep.
Thoughts, Ideas ? :mrgreen:
Hopefully I'm not committing a "Jeep sin" by wanting to remove a skid plate
Thanks,
-Nick :!:
			Hi,
Thanks,
-Nick :!:
