ezwrangler
OK, I have finished putting in the reman engine in my 1994 YJ (thanks for those of you who have answered my questions along the way - it really has been helpful!!!). I have primed the engine with oil (drill and a long screwdriver), cylinder number one is set a TDC, the distributor is installed and I should be ready to go. Reading the Haynes (and several posts) it is emphasized that the timing needs to be set/adjsted as soon as possible after firing it up - but it footnotes that this is for carb engines only (mine is the 4.0L fuel injected). So, my question is, do I need to worry about anything with this engine? Is there any adjustement I need to make after firing it up? Does the computer do all this for you? There is no discussion about adjusting timing on the MPI engines in the Haynes as far as I can tell. After all the time, energy and $'s I've put into this thing, I dont want to blow it right at the end...
Also, I put in 10W30 as the manual suggests, but some posts suggest that there is not enough zinc(?) in the newer run-of-the-mill oils to successfully break in a reman engine??? Some suggest using a high quality diesel oil 15W40 like Rotella etc. Anyone have any opinions on this? Should I drain the 10W30 out and put in the heavier oil during breakin?
thanks for any insight here... :?|
