tires&wheels
ronnieb
4 tires,31x10 50r15lt wheels black imitation street lock 400.00
hey guys....&gals, lots of lookers but not many replies, is it too far away, the cost? will work with you on it , whats up?
will they fit on a 73 CJ5? If so whats your bottom dollar? I will be in RED STICK on the weekend of Sep. 26th & 27th
they came off a 97' wrangler sport 4.0L with 5 lugs .you'll have to check with the guys&gals on that fit, 300. bottom .
what do I measure to see, sure would like to have these, ronnie can you measure from hole to hole and let me know
Josh
those 5 on 5.5 on 5 holes 5 1/2 inch apart
run a tape from middle of stud to middle of next stud
5 holes 4 1/2 inch apart 5 on 4.5
just measured the lug and they are 5 1/4 will yours work if so I want them and can pick up next weekend
the 4.5 indicates the bolt hole circle (BC) an imaginary circle going through the center of all the holes. The '73 like was said before has the 5.5 BC and can't be made to fit even with the BIGGEST hammer or else them suckers would be out here in AZ by now on my 3B.:deadhorse:
i measured from center of hole to next center of hole is 2.5'', if that makes it easy.
