1048874
Hey, peeps...
I've got a question for those of you that understand transmission repair... I myself have a very limited knowledge of how these things actually work, so bear with me...
Okay, i have an '82 CJ7 with 4 speed manual, and i've owned it and been pouring thousands into gettting it all fixed up since... oooh, about august...
I've been noticing lately that DOWNSHIFTING into first gear is really sticky... It just doesnt want to pop in until i'm almost at a stop.... Other times it pops in just fine...
I havent noticed any slippage while the clutch is engaged and i havent noticed any other problems with it "Sticking" when i try to downshift with the exception of the transfer case (engaging and disengaging 4wd is pretty sticky because it doesnt get used much)
Now i recently took my jeep into the shop to get them to fix some OTHER problems (not related to drivetrain) and they recommended that i need a new clutch. (mucho expensive)
Now I'm not at all opposed to getting a brand spanking new clutch put in my old clunker considering it is now 21 years old, and god knows WHAT the previous owners did to the poor thing.
What i'm trying to get stratight in my head right now is if replacing the clutch will solve THIS problem, and thats where things are starting to get a bit grey...
Now if i understand correctly, problems with downshifting into first would be more related to the synchros than anything else, wouldnt it? Are the synchro's part of a clutch replacement? Are there any other parts that i should be replacing while they are in there? Could this be something as simple as maybe just some low transmission fluid? (which i have NO way to check without taking it in for service)
I've already been looking through the documents on "howstuffworks.com" and that info is pretty basic and doesnt really help me understand if replacing the clutch is the right thing to do for this problem or not...
Hey, peeps...
