So I was goin to order mopar springs on 5249464 Mopar Performance Valve Springs 5249464 - Free Shipping on Orders Over $99 at Summit Racing remcomemded by comp cams. For the cam they are grinding for me.. the problem is i can't find the springs in stock anywhere. My 4.0l is sitting here waiting to be reassembled just need the springs to finish it up.. anyone know where I can get some? Someone have a set they are willing to sell? Or know of another spring that will work without machining the head? Don't really wanna take another trip to the machine shop unless I have to.. if I can't track down the Mopar springs what other springs should I use? I've hear z28 springs (from what year motor)
Motor specs:
Stock 93 bottom end
7102 ported and milled head (.016")
T3t4 turbo 9psi
24lb/hr injectors.. (worked fine with the renix 4l may have to go bigger with new motor and cam)
Cam specs:
Valve lift intake/ exhaust .478"
Tappet lift intake/ exhaust .252
Lobe lift intake/ exhaust .2990
Duration @ .050" intake/ exhaust .208
Intake centerline 111
Lobe separation 114
Rocker arm ratio 1.60
			Motor specs:
Stock 93 bottom end
T3t4 turbo 9psi
Cam specs:
Lobe separation 114
