So my 07 2 door jk 3.8.....it started with a p0301 misfire in cylinder 1, so I changed cylinder 1 spark plug.
then it through p0303 misfire in cylinder 3, so I changed all of the spark plugs and the plug wires.
then it through just a p0300 misfire in random cylinders.
the Jeep runs fine, no sputtering or anything, it is a little choppy when I first start it.
so I changed the coil pack.
still throwing a p0300 misfire in random cylinders.
but no other codes, no sputtering or running bad.
what else could cause just a p0300 and no other codes?
i have a suspicious feeling my shitty neighbor might have put something in my gas tank, could that cause it?
i know I can try the cam shaft position sensor and the crank shaft position sensor, but if those were bad it would throw additional codes.
mid it was a bad injector it would throw a misfire in that specific cylinder, but it isn’t.
any suggestions y’all?
