What's the biggest size tires?
1063003
33's thats about it , depending on everything else you might get a little rub on extreme flex.... :-O [addsig]
1063005
33's yup but with a 31" tire you would have plenty of clearance, The gearing would not need to be messed with, the cost would be less, you would only loose 1" of clearance, but they would not look as good! Tug[addsig]
1063020
33's might fit but it will be a street jeep. You generally need a minimum of 4" for 33's and probably an inch or 2 more if you offroad much on a YJ anyway. TJ's can fit a bit bigger tire with less lift because of their flares. I would suggest 31's or maybe 32's but I think 33's might be too big. I have a 4" lift and 31's and have absolutely no clearance problems at all. When I upgrade to 33's I am going to put on some TJ flares for extra clearance and maybe a 1 inch body lift.[addsig]
1063678
is this true with the TJ as well? the 3"lift enabiling the installation of 33's?[addsig]
