Zipper Lube
kenjr
What do you use for a lubrication for the Zippers on your soft top? Any sugestions appreciated. Thank You in advance.........
Clean the teeth really good. I use a bar of soap. The soap is a good lubricant and if it gets dirty it washes off cleaning your zipper teeth. It's cheap and easy to apply.
Some use wax. There are some top care products out there as well.
If you have an issue with the teeth not meshing together well, try pinching the back of the zipper together with a pair of pliers.
