This is a straight forward mount for your Jeep's aftermarket amplifier from Skinny Pedal. The bracket looks pretty simple, and my first thought was "hey, I could have made this!", however after spending about an hour wrestling it into place, I've since changed my mind. The small amount of space available under the dash would make test fitting your amp and fabbing up a bracket from scratch a nightmare.
This bracket is made to hold an Apline PDX amp (or similar), and mounts behind the dash, above the brake pedal, attached to the steering column. There is just barely enough room under the dash for this bracket and the amp to fit, but once you manage to get this into place, it's a perfect solution.
So now, not only is my amp out of sight of thieves, but it's also shielded from light rain and damage. I'm very happy with my new amp mount, and would recomment it to anyone looking for an amp solution.
This is the bracket from Skinny Pedal.
This is how it sits on top of an Alpine PDX amp
And this is how it looks after it's mounted
