replaced front caliper on yj 1994
lets see if i can attach two pix.. there it is. note the bent caliper tab ! solved the mystery of why caliper ceased occasionaly. i plan to heat the tap and drive back into line. i did buy a new caliper (94 jeep yj used a GM caliper). vinn p.s. thanks monitor
You dood it. My oh my, yes, that does look bad. Worn out if you ask me. You need new ones.
well, today ill try to explain the two pix [above] showing the front rotor (94 yj). the two bolt caliper has been removed. note , one of the two bolt tabs is BENT. the caused problem was "occasional brake seize up", AND skid,smoke and PANIC. with torch and hammer, i put the tab back in line with its companion. $50 rebuilt G M caliper with an aluminum piston (instead of the fiber glass one. works good now. p.s. keep a 5 pound hand sledge hammer in the cab in case you need free one up ! so as to limp home. vinn
Forgot to post on saturday and sunday because of how busy we were. Sold my 87 wrangler to a kid and his dad. While driving it home, the transmission cooler line popped off and dumped a bunch of transmission fluid on the ground and we are not sure if they burned the trans up, or not.
All that work swapping the powertain and i never finished it enough to drive it around. I hope the trans is ok and i hope they enjoy that old wrangler. It was a fun jeep
I replaced my radiator last night in the 100 degree weather, that was fun lol. I'm also tinkering with my homemade drop down aluminum tailgate conversion.
Finally found found windshield & frame for 94. Came with new weather seal also. Just got to get back on track & install, along with the new door seals & gaskets for hard top.
Anyone need a CJ windshield & frame and some visors ? See 4 Sale section for pictures.
*Possible trade for yj tailgate?
Installed windshield & driver door seal tomorrow right side goes on . Put hard top back on. Road test Franken Jeep lives again!
I had to take a wet vac to my Jeep to suck out all the rainwater.
I thought I could beat the odds on a 20% chance or rain.
Worked on my 04 TJ Rubicon as its going up for sale. Washed & detailed outside. Did interior detail a couple days prior and removed the excess stuff. Picked up 2016 JKU (Firecracker Red) last weekend. Black plasti-dip sprayed the silver antenna. Picked up some red high temp paint for the calipers.
94 yj drain " check valves". i removed the plugs and added a "loose fit carriage bolt" [no carpets] that lets water pass. i dont know where that water comes from, but i suspect the air box on the cowl. vinn
Put some rattle can black on the (bare metal) drive shafts before they rust.
