Joopin
Super Moderator
Last week I ordered some Bushwacker cut-away fender flares from Quadratec. When ordering them I asked if there was a template to go by for cutting the YJ tub. They said there were measurements to go by, so I thought, that's just as good.
I installed them right away (last friday) and when it came to cutting the body, the front went fine... but the rear was a different story. I cut the front of the rear wheel opening and ran into some tough plastic matierial. It seemed to be NOT part of the mud guards... so I only cut the one side since it seemed like the wrong place to cut. On the rear of the rear openings the instructions ended up telling me to cut less than an inch off... I didn' think much of it until I put on the rear flares then looked underneath, I could have cut another 3 inches or so! And there was nothing to get in the way either. I can always cut more off later though.
Questions: Has anyone installed anything like this? Did you run into the same problems I did? Any ideas on how to clean up where I cut the jeep? (no more bend back and may be over exposed and proned to rust)
Thanks
Joop
BTW, The finished product does look great, I will post some pics later tonight.
Thanks
Joop
