Jeep Grand Cherokee issues
onkcharles
Hi everyone, I’m new but need some help. I have a 2019 jgc srt with a little over 46000 miles and it’s now starting to give issues. Just took it to 2 different mechanics including jeep dealership and no one found the issue. I’m getting cold starts from the ignition but not the keyfob plus I have 2 collision lights and the traction control light on. Both mechanics didn’t find those issues but they found others that when “fixed” didn’t fix those initial issues. Jeep found gasket leaks and the other mechanic changed the transfer case module but I still have the same issues. Please help.
How is your battery. Thats an automatic go to for teplacing on new cars when they start having odd electrical issues
Both mechanics did that. It just came home from the latest mechanic after spending month and them running multiple extensive diagnostics. They sent it home and said to drive it for a while longer until the issue intensify to the point where a diagnosis can pick it up. As a female, that’s telling me to drive it until something gives. I’m consistent with my maintenance always doing them on the specified dates so I know it’s not that I did not keep up with the maintenance.
Is this your keyfob that worked and now doesn’t? Not a spare or replacement?
Has the Keyfob battery been replaced?
Just confirming this function worked for you and not said to work from previous owner or others???
Also confirming what was done to confirm the battery was good?? When batteries start to fail you start getting phantom codes amd no remote start conditions.
With collision and traction lights on was the vehicle in any accident or water damage?
