I started installing the JKS disconnects on my 97 TJ last night. Getting the old linkages off was a pain, but I finally got them off after a good hour or so of trying. Anyway, when I tried to install the disconnect pin on the lower bracket, the threaded side of the pin would not fit through the hole in the bracket. Has anyone else run into this? It's fairly close, but the hole is just a little bit smaller. I'm not sure if I should drill this out bigger or what. It'll be tough to get a drill in there, and I'm afraid of making it too big and introducing some slop into the system. Any suggestions?
