New jeep followed me home
In the last month, the jeep has not been driven. It won't start and says no bus on the cluster. It looks luke the black plug that the cluster plugs into has some issues... it acts like the clustee pins are not making good contact.
Dont know how to fix that though
Maybe some spray electronics cleaner to try and get the pins shined up a bit? I'd try cleaning and wiggling the wires before I tried replacing the cluster.
Look at the wires going into the back of the plug to be sure none are backing out. The CrC. QD Contact Cleaner.
Disconnect the battery and clear the code.
Check the battery is fully charged.
Mine sits too long and the battery slowly drains.
Well, jeep is still dead.
I was looking through the folder the previous owner gave me and he had to replace the crank sensor a number of times. Kind of odd.
And its been rainy and cold so that sucks.
Yesterday i had hernia surgery too so now i have to wait till that heals.
Since i am bored and cant do anything i did order a new crank sensor for it. Just for the heck of it
Make sure it has a paper gasket on the tip. That sets the spacing from the flywheel. Without it you may crack or destroy it on the first turn.
New crank sensor, wiper motor, and key switch and nothing. I did order a new ecu because i found thay the fuel pump runs non stop when the key is in the run position instead of just priming and turning off. And the ecu that is in the jeep is a junkyard replacement that looks like someone ran it over.
Hopefully the ecu gets it back running.
Ok, she is back to normal and ready to be a daily driver. New ecu fixed the issue.
I also fixed all the wires that were worn through and rubbing the body in different spots. I kind of think that is what shorted the ecu, not so much how bad it looked
She may be going to its forever home tomorrow. I had it on marketplace for 6k and a guy messaged me to see it. He came and checked it amd test drove it for about 29 mins and ssid he liked it snd will take it.
He amlnd his wife are retired and want a jeep to pull behind the rv and think this will be perfect to run around the camp ground and run to the supermarket in.
I am glad its going to someone who will take care of it and use it instead of it becoming a beach jeep that gets trashed out
He came and picked it up today. They are excited to bring it home and do somw upgrades to get it ready to be a retirement jeep.
I am happy its going to someone who is going to take care of it and love it
