michaelc291
Member
Thanks again for the replies. I was not sure about the thread tape on the new sender so I did a continuity test on it and it was connecting with the head.  I guess the thread cuts through the tape when you tighten it.
I have tested the relay off the car as well as swapping a couple of them. No problems.
I searched for a second sensor but could not find one in the rad. The boss is there just above the bottom hose connection though. The ones in the head are all accounted for.
In case you have noticed there is no visible compressor for the aircon. This is because it's under the power steering pump and the bottom hose wraps itself all round it. To change the hose takes at least a day. The pump has to come off, the compressor has to come off, the mechanical fan has to come off complete with its bracket and that's just a start. It's the worst hose I have ever had to change in my life and it's not a cheap part. My knuckles always suffer.
On the other hand the top hose is very easy.
I have ordered a new NTK O2 sensor from RockAuto just to eliminate it from the equation. Sadly the price gets doubled with shipping and duty by the time it gets here.
A couple of my friends have said just scrap it and get something newer. I could not do that, it's part of the family, anyway I have a 2004 Chrysler Sebring convertible which is great fun over here in Spain, however they are known for reliability problems which I didn't know about when I bought it. But that's another (rather long) story.
I have attached a diagram for the fan relay which seems to show that it's controlled from the ECU.
