bradleyheathhays
Member
I developed a bit of death wobble in the old 96er recently and traced it to the driver side connection of my track bar, so I'm in the middle of getting it out.  I've been soaking the passenger side connection in the picture below with PB for a while now, and it's still distressingly hard to turn.  I can get the red bolt head to turn some using 4-5" worth of cheater bar on my 3/8" ratchet, but only until the yellow nut tab reaches it's limit of travel within the rectangular hole it protrudes through.  I keep doing PB soaks, torches followed by cold water dousing cycles, but it's not getting any easier to turn at all.  The nut is rotating with the bolt because the tab moves when I turn the bolt, so the nut is not what's holding it up.  My best idea is that the bolt has rusted to the metal sleeve in the track bar bushing and that sleeve is rotating with the bolt, held by the friction against the rubber.  I haven't even tried to rotate the bolt past where the nut tab comes in contact with it's limits as I'm almost putting enough torque on it to twist the head off already.
Any advice on working this thing?
Also, say the bolt head were to snap off. What would you do to get the bolt out? My only idea would be to try to push the bolt through from the head side with an awl or something smaller than the bolt diameter, then try to get an oscillating cutter up into that window on the right and piece by piece cut the end of the bolt off until it all comes through. Thoughts?
