LVRockCrawler
is the turn signal problem in the switch or is the stalk broken - the switch is an easier fix - the stalk is a bit more work to R/R as you have to disassemble more behind the wheel - you dont have to pull the column for either (done both) let me know and i'll try to walk ya thru it.... ALSO... make sure you check the valve cover - they are NOTORIOUS for loosening up, leaking, running down the back/side of the block and looking like a pan/rear seal leak....
